mgmtgwd.replace events
Creating your file...
Your file is ready
mgmtgwd.replace.node.mgmt.lif
- Severity
ERROR
- Description
This message occurs when the temporary node management LIF, which is normally deleted automatically, has not been replaced. It should be replaced to free the DHCP address.
- Corrective Action
Create a new node management LIF by using the 'network interface create' command, and then delete the temporary node management LIF by using the 'network interface delete' command.
- Syslog Message
Temporary node management LIF '%s' should be replaced with a new node management LIF.
- Parameters
lif (STRING): Temporary node management LIF.
