The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
mgmtgwd.replace events
Creating your file...
Your file is ready
mgmtgwd.replace.node.mgmt.lif
- Severity
ERROR
- Description
This message occurs when the temporary node management LIF, which is normally deleted automatically, has not been replaced. It should be replaced to free the DHCP address.
- Corrective Action
Create a new node management LIF by using the 'network interface create' command, and then delete the temporary node management LIF by using the 'network interface delete' command.
- Syslog Message
Temporary node management LIF '%s' should be replaced with a new node management LIF.
- Parameters
lif (STRING): Temporary node management LIF.
