disk.checksum events
Creating your file...
disk.checksum.offlineAdapter
- Severity
ALERT
- Description
This message occurs when multiple errors are detected during checksum verification. The adapter is taken offline.
- Corrective Action
Replace the adapter. Contact Contact NetApp technical support. for assistance with a Return Material Authorization.
- Syslog Message
Adapter %s taken offline due to checksum verification failure on multiple disks. Keep the adapter offline and contact Contact NetApp technical support. for assistance.
- Parameters
adapterName (STRING): Name of the adapter.
disk.checksum.verifyFailed
- Severity
ALERT
- Description
This message occurs when disk checksum verify fails.
- Corrective Action
(None).
- Syslog Message
Disk level checksum verification failed on WRITE VERIFY: Disk %s, Block #%llu: Volume %s, FileId %d, Block #%llu
- Parameters
diskName (STRING): Name of the device.
bno (LONGINT): block id
vol (STRING): Volume name.
fileid (INT): File ID.
block (LONGINT): File block ID.
