ONTAP EMS reference
disk.checksum events
disk.checksum.offlineAdapter
Severity
ALERT
This message occurs when multiple errors are detected during checksum verification. The adapter is taken offline.
Corrective Action
Replace the adapter. Contact Contact NetApp technical support. for assistance with a Return Material Authorization.
Syslog Message
Adapter %s taken offline due to checksum verification failure on multiple disks. Keep the adapter offline and contact Contact NetApp technical support. for assistance.
adapterName (STRING): Name of the adapter.
disk.checksum.verifyFailed
Severity
ALERT
This message occurs when disk checksum verify fails.
Corrective Action
(None).
Syslog Message
Disk level checksum verification failed on WRITE VERIFY: Disk %s, Block #%llu: Volume %s, FileId %d, Block #%llu
diskName (STRING): Name of the device.
bno (LONGINT): block id
vol (STRING): Volume name.
fileid (INT): File ID.
block (LONGINT): File block ID.
