ONTAP EMS reference
ccma.perfstatd events
ccma.perfstatd EMS events occur when the Perfstat daemon (perfstatd) has been disabled for more than an hour.
ccma.perfstatd.disabled
Severity
ERROR
This message occurs when the Perfstat daemon (perfstatd) has been disabled for more than an hour. This is caused by setting the -perfstat-sampling-period value to 0. This message will be repeated every hour perfstatd is turned off. The messages will only displayed once a day.
Corrective Action
Run the 'statistics archive config modify -perfstat-sampling-period 5' command. This will enable the perfstatd and it will set the Perfstat sampling period to the default value of 5 minutes.
Syslog Message
The Perfstat daemon (perfstatd) has been disabled for more than an hour. It is important for the analysis and diagnoses of performance related issues. Consider enabling it.
(None).
