ONTAP EMS reference
config.bridge events
config.bridge.adapter.invalid
Severity
ERROR
This message occurs when an FC-to-SAS bridge is attached to an unsupported FC adapter port. Only QLogic® 4-Gb/s or 8-Gb/s adapters are supported.
Corrective Action
Attach the FC-to-SAS bridge to a supported FC adapter port on the controller.
Syslog Message
FC-to-SAS bridge %s S/N [%s] is attached to unsupported FC adapter port %s.
bridgeName (STRING): Name of the FC-to-SAS bridge.
bridgeSerialNum (STRING): Serial number of the FC-to-SAS bridge.
adapterName (STRING): Name of the associated FC host bus adapter.
config.bridge.extra.port
Severity
ERROR
This message occurs when both FC ports of an FC-to-SAS bridge are attached to the same controller.
Corrective Action
Follow the defined Fabric or Stretch MetroCluster wiring guide.
Syslog Message
Both FC ports of FC-to-SAS bridge %s S/N [%s] are attached to this controller.
config.bridge.fw.mismatch
Severity
ERROR
This message occurs when two or more attached FC-to-SAS bridges are running different firmware revisions.
Corrective Action
For more information about downloading and installing updated firmware, check your support provider's web site or knowledgebase.
Syslog Message
Two or more %s FC-to-SAS bridges are running different firmware revisions.
bridgeModel (STRING): Name of the FC-to-SAS bridge model.
config.bridge.SAS.miswired
Severity
ERROR
This message occurs when the SAS disk shelves behind an FC-to-SAS bridge are not wired in the correct order.
Corrective Action
Syslog Message
The SAS disk shelves behind FC-to-SAS bridge %s S/N [%s] are not correctly wired.
config.bridge.SAS2Domain
Severity
ERROR
This message occurs when a disk is multipathed to one SAS domain; that is, both ports of the disk are visible from the same bridge FC port.
Corrective Action
Recable the disk shelf containing the specified disk, so that the two disk ports are in different SAS domains.
Syslog Message
Disk %s is multipathed to the same SAS domain. The two disk ports must be in different SAS domains.
disk (STRING): Name of the disk.
config.bridge.unsupp.shelf
Severity
ALERT
This message occurs when an FC-to-SAS bridge discovers a disk shelf that it does not support.
Corrective Action
Verify the bridge firmware is up-to-date with minimum FW rev required for support of this shelf type. If the bridge firmware supports the disk shelf but the error condition persists, remove the disk shelf.
Syslog Message
FC-to-SAS %s bridge with S/N: %s WWN: %s has unsupported %s shelf type attached.
bridgeType (STRING): Type of FC-to-SAS bridge.
bridgeSerialNum (STRING): Serial number of the bridge.
bridgeWWN (STRING): World Wide Name of the bridge.
shelfType (STRING): Type of shelf.
