ONTAP EMS reference
osc.signaturemismatch events
osc.signaturemismatch EMS events occur when the request signature sent to the object-store server does not match the signature calculated.
osc.signatureMismatch
Severity
ERROR
This message occurs when the request signature sent to the object-store server does not match the signature calculated.
Corrective Action
Verify that the secret access key is configured correctly. If it is correct, contact NetApp technical support for assistance.
Syslog Message
Object-store %s operation server-calculated request signature does not match the signature sent to object-store server %s for bucket or container "%s" on node %s. Check the keys and signing method.
operation (STRING): Request name.
serverHostname (STRING): Hostname of the object-store server.
bucket (STRING): Name of the object-store bucket.
nodeUuid (STRING): UUID of the node.
