The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
sectrace.warning events
Creating your file...
Your file is ready
sectrace.warning.aboutperf
- Severity
ALERT
- Description
This message occurs when a security tracing filter is enabled. It can cause a significant performance degradation and should be disabled as soon as it is no longer needed.
- Corrective Action
Consider disabling the Security tracing filters as soon as it is no longer needed. 'sectrace filter modify -vserver [id] -index [index] -enabled disabled'
- Syslog Message
Security tracing is enabled on Vserver %s for the next %d minutes.
- Parameters
vservername (STRING): Name of the vserver on which file/directory tracing is enabled.
duration (INT): Duration of the sectrace filter that is enabled.
