config.repl events
config.repl.bypass.disabled
Severity
NOTICE
This message occurs when the configuration replication bypass has been disabled. Configuration replication to any partner clusters will now resume.
Corrective Action
(None).
Syslog Message
The configuration replication bypass has been disabled.
(None).
config.repl.bypass.enabled
Severity
NOTICE
This message occurs when the configuration replication bypass has been enabled. Configuration replication to any partner clusters will cease until the bypass is disabled using the 'debug crs replication-bypass disable' command.
Corrective Action
(None).
Syslog Message
The configuration replication bypass has been enabled.
(None).
