The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
ses.inconsistent events
Creating your file...
Your file is ready
ses.inconsistent.config
- Severity
ALERT
- Description
This message occurs when the system detects an inconsistent configuration of shelf-to-channel connections. One or more shelves on the reported channel are connected to a different set of channels (adapter ports or switch ports) than other shelves in the stack.
- Corrective Action
Verify that all cables are fully inserted on the storage shelves connected to the channel. Verify that the shelves are cabled so that all shelves in a stack are connected to the same channels.
- Syslog Message
Inconsistent configuration detected for shelf connected to adapter %s.
- Parameters
channelName (STRING): Name of the adapter port or switch port where shelf connection inconsistencies are found.
