ses.inconsistent events
Creating your file...
Your file is ready
ses.inconsistent.config
- Severity
ALERT
- Description
This message occurs when the system detects an inconsistent configuration of shelf-to-channel connections. One or more shelves on the reported channel are connected to a different set of channels (adapter ports or switch ports) than other shelves in the stack.
- Corrective Action
Verify that all cables are fully inserted on the storage shelves connected to the channel. Verify that the shelves are cabled so that all shelves in a stack are connected to the same channels.
- Syslog Message
Inconsistent configuration detected for shelf connected to adapter %s.
- Parameters
channelName (STRING): Name of the adapter port or switch port where shelf connection inconsistencies are found.
