ONTAP EMS reference
ses.inconsistent events
ses.inconsistent.config
Severity
ALERT
This message occurs when the system detects an inconsistent configuration of shelf-to-channel connections. One or more shelves on the reported channel are connected to a different set of channels (adapter ports or switch ports) than other shelves in the stack.
Corrective Action
Verify that all cables are fully inserted on the storage shelves connected to the channel. Verify that the shelves are cabled so that all shelves in a stack are connected to the same channels.
Syslog Message
Inconsistent configuration detected for shelf connected to adapter %s.
channelName (STRING): Name of the adapter port or switch port where shelf connection inconsistencies are found.
