ONTAP EMS reference
tcpip.duplicate events
tcpip.duplicate EMS events occur when the local node detects that it and some other device are using the same IP address.
tcpip.duplicate.ip
Severity
ERROR
This message occurs when the local node detects that it and some other device are using the same IP address.
Corrective Action
Check the IP address configuration on both the local node and the device using the Ethernet MAC address. Modify or remove the IP address on whichever device is misconfigured.
Syslog Message
Duplicate IP address %s sent from link address %s.
ipAddress (STRING): IP address under contention.
macAddress (STRING): Ethernet MAC address of the other device.
