      tcpip.duplicate events
tcpip.duplicate.ip
- Severity
ERROR
 - Description
This message occurs when the local node detects that it and some other device are using the same IP address.
 - Corrective Action
Check the IP address configuration on both the local node and the device using the Ethernet MAC address. Modify or remove the IP address on whichever device is misconfigured.
 - Syslog Message
Duplicate IP address %s sent from link address %s.
 - Parameters
ipAddress (STRING): IP address under contention.
macAddress (STRING): Ethernet MAC address of the other device.
