asa.personality events
asa.personality EMS events occur when ONTAP encounters issues associated with cluster personality conversion to an All SAN Array.
asa.personality.enable.end
- Severity
NOTICE
- Description
This message occurs when the cluster personality has been changed to an All SAN Array.
- Corrective Action
(None).
- Syslog Message
The cluster personality is now an All SAN Array.
- Parameters
job_id (LONGINT): ID of the conversion job.
asa.personality.enable.fail
- Severity
ERROR
- Description
This message occurs when the job to change the cluster personality to an All SAN Array has failed.
- Corrective Action
Attempt the failed command again. If the problem persists, contact NetApp technical support.
- Syslog Message
The cluster personality was not changed to an All SAN Array. For more information, use the command "job show -id %llu" to see the job details.
- Parameters
asa.personality.enable.start
- Severity
NOTICE
- Description
This message occurs when the cluster personality is being changed to All SAN Array.
- Corrective Action
(None).
- Syslog Message
The cluster personality is changing to All SAN Array.
- Parameters
