ONTAP EMS reference
asa.personality events
asa.personality.enable.end
Severity
NOTICE
This message occurs when the cluster personality has been changed to an All SAN Array.
Corrective Action
(None).
Syslog Message
The cluster personality is now an All SAN Array.
job_id (LONGINT): ID of the conversion job.
asa.personality.enable.fail
Severity
ERROR
This message occurs when the job to change the cluster personality to an All SAN Array has failed.
Corrective Action
Attempt the failed command again. If the problem persists, contact NetApp technical support.
Syslog Message
The cluster personality was not changed to an All SAN Array. For more information, use the command "job show -id %llu" to see the job details.
asa.personality.enable.start
Severity
NOTICE
This message occurs when the cluster personality is being changed to All SAN Array.
Corrective Action
(None).
Syslog Message
The cluster personality is changing to All SAN Array.
