The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
malloc.failure events
Creating your file...
Your file is ready
malloc.failure
- Severity
ERROR
- Description
This event is generated if malloc is called unsafely.
- Corrective Action
(None).
- Syslog Message
%s %s %s %s %s %s %s %s %s %s %s
- Parameters
f2 (STRING): Third frame of backtrace.
f3 (STRING): Fourth frame of backtrace.
f4 (STRING): Fifth frame of backtrace.
f5 (STRING): Sixth frame of backtrace.
f6 (STRING): Seventh frame of backtrace.
f7 (STRING): Eighth frame of backtrace.
f8 (STRING): Ninth frame of backtrace.
f9 (STRING): Tenth frame of backtrace.
f10 (STRING): Eleventh frame of backtrace.
f11 (STRING): Twelfth frame of backtrace.
f12 (STRING): Thirteenth frame of backtrace.
malloc.failure.detail
- Severity
ERROR
- Description
- Corrective Action
(None).
- Syslog Message
%s %s
- Parameters
description (STRING): Description of failure.
buffers (STRING): Details of buffers that were predirtied.
