wafl.reallocate events
Creating your file...
wafl.reallocate.aggr.interrupt
- Severity
INFORMATIONAL
- Description
This message occurs when an aggregate reallocation scan is interrupted. The scan was scheduled using the 'reallocate -A' command.
- Corrective Action
None required.
- Syslog Message
Aggregate reallocation scan on '%s' was interrupted.
- Parameters
path (STRING): Scan path.
wafl.reallocate.check.high
- Severity
INFORMATIONAL
- Description
This event is issued if an allocation check scan (issued before reallocation starts) returns indicating that the path requires reallocation.
- Corrective Action
None required. The reallocation scan will automatically be started.
- Syslog Message
Allocation check on '%s' is %d, hotspot %d (threshold %d), so will reallocate.
- Parameters
path (STRING): The scan path
optim (INT): The current optimization of the path
hot_spot (INT): The current hot-spot optimization of the path
threshold (INT): The reallocation threshold of the path
wafl.reallocate.check.highAdvise
- Severity
INFORMATIONAL
- Description
This event is issued if an allocation check scan returns indicating that the path would benefit from reallocation.
- Corrective Action
Consider reallocating the path (see na_reallocate(1))
- Syslog Message
Allocation check on '%s' is %d, hotspot %d (threshold %d), consider running reallocate.
- Parameters
wafl.reallocate.check.value
- Severity
INFORMATIONAL
- Description
This event is issued to report the optimization of a path.
- Corrective Action
None required.
- Syslog Message
Allocation measurement check on '%s' is %d.
- Parameters
optim (INT): The path optimization.
wafl.reallocate.full.done
- Severity
INFORMATIONAL
- Description
This event is issued to report the completion of a full, one-time, reallocation scan.
- Corrective Action
None required.
- Syslog Message
Full reallocation on '%s' is complete.
- Parameters
wafl.reallocate.full.interrupt
- Severity
INFORMATIONAL
- Description
This event is issued to report that a full, one-time, reallocation scan was interrupted.
- Corrective Action
None required.
- Syslog Message
Full reallocation on '%s' was interrupted.
- Parameters
wafl.reallocate.path.invalid
- Severity
ERROR
- Description
This event is issued if an invalid scan path is detected.
- Corrective Action
Check why the scan path is invalid, including file removal or volume offline. If the condition is persistent remove the associated reallocation scan.
- Syslog Message
Unavailable/invalid reallocation path '%s' detected.
- Parameters
wafl.reallocate.recheck.ok
- Severity
INFORMATIONAL
- Description
This event is issued if an allocation recheck scan (issued after reallocation has completed) returns indicating the optimization is under the threshold.
- Corrective Action
None required.
- Syslog Message
Allocation check on '%s' is under threshold.
- Parameters
wafl.reallocate.scan.exists
- Severity
INFORMATIONAL
- Description
This event is issued if an attempt is made to add a new reallocation scan but a scan job already exists for the supplied path.
- Corrective Action
Check the path is correct. If it is correct then delete the previous reallocation job, and add a new one. Use the 'reallocate status' command to list reallocation jobs.
- Syslog Message
A reallocation scan for %s already exists.
- Parameters
path (STRING): The path with the scan.
wafl.reallocate.scan.noStart
- Severity
NOTICE
- Description
Reallocation tasks, such as measuring the layout of a file or performing block reallocation, may be perfomed using an asynchronous WAFL scanner. This event is issued if an error occurs unexpectedly while trying to start such a WAFL scanner.
- Corrective Action
(Call support).
- Syslog Message
reallocate: unable to start '%s' scanner for '%s': %d (%s)
- Parameters
scan_type (STRING): The type of scan operation.
path (STRING): The scan path or aggregate name.
err_code (INT): A numerical error code indicating the reason why the scanner could not be started.
err_string (STRING): A string interpreting the err_code.
wafl.reallocate.scan.remove
- Severity
INFORMATIONAL
- Description
This event is issued when a reallocation job is persistently removed from the system.
- Corrective Action
None required.
- Syslog Message
Reallocation scan for '%s' is being removed.
- Parameters
wafl.reallocate.schedule.invalid
- Severity
ERROR
- Description
This event is issued if an invalid reallocation schedule is detected.
- Corrective Action
Correct the schedule syntax then retry the operation
- Syslog Message
Invalid schedule: %s
- Parameters
reason (STRING): The reason why the schedule is invalid
