The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
ctl.session events
Creating your file...
Your file is ready
ctl.session.stateChanged
- Severity
NOTICE
- Description
This message occurs when iSCSI CAM target layer session status is changed.
- Corrective Action
If the identified iSCSI CAM target layer session is experiencing unexpected events (disconnecting, reconnecting, or connected), examine the link for excessive errors or latency.
- Syslog Message
iSCSI CAM target layer's session state is changed to %s for the initiator %s (address: %s). %s
- Parameters
ctl_session_state (STRING): New iSCSI CAM target layer session state.
ctl_initiator (STRING): iSCSI CAM target layer initiator's name.
ctl_initiator_address (STRING): iSCSI CAM target layer initiator's address.
ctl_session_state_change_reason (STRING): Reason for the iSCSI CAM target layer session state change.
ctl_timeout_value (INT): iSCSI CAM target layer timeout value.
