nblade.nfsv4poolexhaust events
nblade.nfsv4poolexhaust EMS events occur when one of the NFSv4 store pools is exhausted.
Nblade.nfsV4PoolExhaust
- Severity
EMERGENCY
- Description
This message occurs when one of the NFSv4 store pools is exhausted.
- Corrective Action
If the NFS server is unresponsive for more than 10 minutes after this error occurs, contact NetApp technical support.
- Syslog Message
NFS Store Pool for %s exhausted. Associated object type is %s with UUID: %s.
- Parameters
poolname (STRING): NFSv4 store pool type where the exhaustion happened.
object_type (STRING): Type of the resource object under notification.
object_uuid (STRING): UUID of the resource object.
