flexcache.config events
flexcache.config EMS events occur when the FlexCache volume expand operation fails to synchronize the FlexCache configuration information between the newly created constituent volume and the origin cluster.
flexcache.config.sync.failed
- Severity
ERROR
- Description
This message occurs when the FlexCache volume expand operation fails to synchronize the FlexCache configuration information between the newly created constituent volume and the origin cluster.
- Corrective Action
Use the "volume flexcache config-refresh" command on the origin cluster to update the FlexCache configuration.
- Syslog Message
Volume expand failed to create the cache configuration for FlexCache volume "%s" in Vserver "%s" on the origin of the FlexCache cluster. Error: %s.
- Parameters
cacheVolName (STRING): Name of the FlexCache volume.
cacheVserver (STRING): Name of the Vserver hosting the FlexCache volume.
errorString (STRING): Error string.
