wafl.root events
wafl.root EMS events occur when ONTAP encounters issues associated with root volume content changes.
wafl.root.autocreate
- Severity
NOTICE
- Description
This event is issued when no online root volume is found. It is used to indicate that auto creation of a root volume will happen.
- Corrective Action
(None).
- Syslog Message
No online root volume found on root aggregate %s. Automatically creating one.
- Parameters
aggr (STRING): The root aggregate name
wafl.root.content.changed
- Severity
ERROR
- Description
This message occurs when the contents of the root volume are changed to those of a previous point in time. One of the following operations or events can cause the contents of the root volume to change: - The root volume is changed from the boot menu. - The nvlog is jettisoned. - The system is booted with prev_cp. - The 'wafliron -prev_cp' command is used and the changes are commited. - A SnapRestore® operation is done on the root volume.
- Corrective Action
Verify that all recent configuration changes are still in effect.
- Syslog Message
Contents of the root volume '%s' might have changed. Verify that all recent configuration changes are still in effect.
- Parameters
vol (STRING): Name of the root volume.
wafl.root.create
- Severity
INFORMATIONAL
- Description
This message occurs when the system creates a root volume.
- Corrective Action
(None).
- Syslog Message
New root volume %s created.
- Parameters
wafl.root.mark.error
- Severity
NOTICE
- Description
This event is issued when there is an error in syncing the vvol raid label of a newly created root volume.
- Corrective Action
(None).
- Syslog Message
Error setting volume %s%s as root. Changes may not be saved.
- Parameters
vol (STRING): The root volume name
app (STRING): Application UUID.
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
wafl.root.overwritesUnsafe
- Severity
ERROR
- Description
This message occurs when the root volume is not volume guaranteed or does not guarantee overwrites for space reserved files.
- Corrective Action
Set the Space Guarantee on the root volume to "volume" and the Fractional Reserve on the root volume to 100%.
- Syslog Message
Root volume %s does not protect overwrites in space reserved files.
- Parameters
vol (STRING): Root volume name.
