The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
aggr.relocation events
Creating your file...
Your file is ready
aggr.relocation.failed
- Severity
ERROR
- Description
This message occurs when relocation of an aggregate fails.
- Corrective Action
Refer to other generated error messages to identify the exact cause of failure and the corrective action.
- Syslog Message
Relocation of aggregate %s failed by node %s because %s.
- Parameters
aggr (STRING): Name of the aggregate that was not relocated.
node (STRING): Name of the node that failed the relocation.
msg (STRING): Error that prevented relocation.
