ONTAP EMS reference
cpeer.modify events
cpeer.modify.address.family
Severity
NOTICE
This message occurs when the address family for a peering relationship is modified. The same configuration change should be made at the peered cluster in a timely manner. Peering services are maintained while intercluster LIFs of both address families are configured on each cluster.
Corrective Action
This is a notification of a configuration change. No corrective action applies.
Syslog Message
Address family change for peer cluster %s to address family %s.
peer (STRING): Name of the peer cluster affected by the address family change.
family (STRING): The new address family of the peering relationship.
