The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
sfu.downloadsuccess events
Creating your file...
Your file is ready
sfu.downloadSuccess
- Severity
INFORMATIONAL
- Description
This message occurs when disk shelf firmware updates successfully.
- Corrective Action
(None).
- Syslog Message
%s: Firmware file %s downloaded on %s.shelf%d.
- Parameters
cmdName (STRING): Name of the command issued, such as "storage shelf firmware update".
fileName (STRING): Name of the file in /etc/shelf_fw that was being downloaded.
channelName (STRING): Name of the adapter port or switch port on which the shelf firmware download occurred.
shelfId (INT): ID of the disk shelf on which the disk shelf firmware download occurred.
