fci.wrong events
fci.wrong.speed
- Severity
NOTICE
- Description
This message occurs when the fixed speed level requested by the fc-force-XG-ports bootarg is out of range for the corresponding FC port.
- Corrective Action
If another fixed speed is desired, adjust accordingly. Otherwise, the port will autonegotiate.
- Syslog Message
Fibre Channel adapter port %s does not support a speed setting of %u Gbps, which does not fall within port range %x.
- Parameters
port (STRING): Name of the adapter port.
speed (INT): Speed the adapter port was assigned.
range (INTHEX): Range of speeds the adapter port is capable of using.
