ONTAP EMS reference
monitor.fan events
monitor.fan EMS events occur when ONTAP encounters issues associated with main unit fan operation.
monitor.fan.critical
Severity
EMERGENCY
This message occurs when one or more main unit fans have failed. The system cannot continue to operate.
Corrective Action
Replace the failed fans.
Syslog Message
%s
report (STRING): Report indicating the critical state.
monitor.fan.failed
Severity
ALERT
This message occurs when one or more main unit fans have failed. The system remains operational. If the condition persists too long, an automatic shutdown for overtemperature might occur.
Corrective Action
Reseat the failed fans. If the error persists, replace them.
Syslog Message
%s
report (STRING): Report indicating the failed fans.
monitor.fan.ok
Severity
NOTICE
This message occurs when a previously failed main unit fan has been restarted.
Corrective Action
(None).
Syslog Message
%s
report (STRING): Report indicating that the failed fans have restarted.
monitor.fan.warning
Severity
NOTICE
This message occurs when one or more fans are in a warning state.
Corrective Action
Replace the indicated fans to avoid overheating.
Syslog Message
%s
report (STRING): Report indicating the warning level.
