repl.large events
repl.large EMS events occur when ONTAP encounters issues associated with large volume limits on replication destinations.
repl.large.vol.limits.unsup
- Severity
ERROR
- Description
This message occurs when the replication engine encounters a destination that cannot handle large volume limits.
- Corrective Action
Take one of the following actions: - Select a destination with version ONTAP 9.12.1 or later. - On the source volume, reduce the volume size "volume modify -vserver vserver_name> -volume vol_name -large-volume-file-limits disable". Now disable large volume limits by using the "volume modify -vserver vserver_name -volume vol_name -large-volume-file-limits disable" command.
- Syslog Message
Large volume limits not supported on the destination node %s for destination volume with MSID %llu of relationship %s.
- Parameters
dstNode (STRING): UUID of the node where the SnapMirror® destination is present.
dstVolMsid (LONGINT): MSID of the SnapMirror® destination volume.
transferId (STRING): UUID of the failed SnapMirror® transfer.
repl.large.vol.unsup.maxvvbn
- Severity
ERROR
- Description
This message occurs when the replication engine encounters a destination that cannot handle large volumes.
- Corrective Action
Select a destination that supports a volume size greater than 100 TB.
- Syslog Message
Large volumes not supported on the destination node %s for destination volume with MSID %llu of relationship %s.
- Parameters
transferId (STRING): UUID of the SnapMirror® transfer that has the destination that cannot handle large volumes.
repl.large.vol.unsup.nomsize
- Severity
ERROR
- Description
- Corrective Action
Take one of the following actions: - On the source volume, disable autosize if it is enabled by using the "volume modify vol_name -autosize-mode" command. Then reduce the size of the volume by using the "volume modify vol_name -size" command. - On the source volume, set the "max autosize" parameter to below 100 TB by using the "volume modify vol_name -max-autosize" command. - On the source volume, reduce the size of the volume to below 100 TB by using the "volume modify vol_name -size" command. - Select a destination that supports a volume size greater than 100 TB.
- Syslog Message
Large volume not supported on the destination node %s for destination volume with MSID %llu of relationship %s.
- Parameters
