ONTAP EMS reference
repl.large events
repl.large EMS events occur when ONTAP encounters issues associated with large volume limits on replication destinations.
repl.large.vol.unsup.maxvvbn
Severity
ERROR
This message occurs when the replication engine encounters a destination that cannot handle large volumes.
Corrective Action
Select a destination that supports a volume size greater than 100 TB.
Syslog Message
Large volumes not supported on the destination node %s for destination volume with MSID %llu of relationship %s.
dstNode (STRING): UUID of the node where the SnapMirror® destination is present.
dstVolMsid (LONGINT): MSID of the SnapMirror® destination volume.
transferId (STRING): UUID of the SnapMirror® transfer that has the destination that cannot handle large volumes.
repl.large.vol.unsup.nomsize
Severity
ERROR
Corrective Action
Take one of the following actions: - On the source volume, disable autosize if it is enabled by using the "volume modify vol_name -autosize-mode" command. Then reduce the size of the volume by using the "volume modify vol_name -size" command. - On the source volume, set the "max autosize" parameter to below 100 TB by using the "volume modify vol_name -max-autosize" command. - On the source volume, reduce the size of the volume to below 100 TB by using the "volume modify vol_name -size" command. - Select a destination that supports a volume size greater than 100 TB.
Syslog Message
Large volume not supported on the destination node %s for destination volume with MSID %llu of relationship %s.
transferId (STRING): UUID of the failed SnapMirror® transfer.
