ONTAP EMS reference
repl.large events
repl.large EMS events occur when ONTAP encounters issues associated with large volume limits on replication destinations.
repl.large.vol.600tb.limits.unsup
Severity
ERROR
This message occurs when the replication engine encounters a destination that cannot handle large 600TB volume limits.
Corrective Action
Take one of the following actions: - Select a destination with version ONTAP 9.14.0 or later. - On the source volume, reduce the volume size "volume modify -vserver vserver_name> -volume vol_name -max-size 300TB".
Syslog Message
Large volume limits not supported on the destination node %s for destination volume with MSID %llu of relationship %s.
dstNode (STRING): UUID of the node where the SnapMirror® destination is present.
dstVolMsid (LONGINT): MSID of the SnapMirror® destination volume.
transferId (STRING): UUID of the failed SnapMirror® transfer.
repl.large.vol.limits.unsup
Severity
ERROR
This message occurs when the replication engine encounters a destination that cannot handle large volume limits.
Corrective Action
Take one of the following actions: - Select a destination with version ONTAP 9.12.1 or later. - On the source volume, reduce the volume size "volume modify -vserver vserver_name> -volume vol_name -large-volume-file-limits disable". Now disable large volume limits by using the "volume modify -vserver vserver_name -volume vol_name -large-volume-file-limits disable" command.
Syslog Message
repl.large.vol.unsup.maxvvbn
Severity
ERROR
This message occurs when the replication engine encounters a destination that cannot handle large volumes.
Corrective Action
Select a destination that supports a volume size greater than 100 TB.
Syslog Message
Large volumes not supported on the destination node %s for destination volume with MSID %llu of relationship %s.
transferId (STRING): UUID of the SnapMirror® transfer that has the destination that cannot handle large volumes.
repl.large.vol.unsup.nomsize
Severity
ERROR
Corrective Action
Take one of the following actions: - On the source volume, disable autosize if it is enabled by using the "volume modify vol_name -autosize-mode" command. Then reduce the size of the volume by using the "volume modify vol_name -size" command. - On the source volume, set the "max autosize" parameter to below 100 TB by using the "volume modify vol_name -max-autosize" command. - On the source volume, reduce the size of the volume to below 100 TB by using the "volume modify vol_name -size" command. - Select a destination that supports a volume size greater than 100 TB.
Syslog Message
Large volume not supported on the destination node %s for destination volume with MSID %llu of relationship %s.
