The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
wafl.upgrade events
Creating your file...
Your file is ready
wafl.upgrade.useActiveInofile
- Severity
NOTICE
- Description
This event is issued during an upgrade where the system need to use the active filesystem inofile.
- Corrective Action
(None).
- Syslog Message
Using active filesystem inofile on upgrade from legacy %s %s%s%s%s.
- Parameters
type (STRING): The type of object (volume/aggregate)
owner (STRING): The owner of the volume
vol (STRING): The name of the volume
app (STRING): Application UUID.
volident (STRING): To uniquely identify the volume in cases where volume name itself is insufficient.
