sis.default events
sis.default EMS events occur when ONTAP encounters issues associated with automatic storage efficiency configuration.
sis.default.auto.se.enable
- Severity
NOTICE
- Description
This message occurs whenever volume move is done from a non All Flash Optimized node to an All Flash Optimized node and we attempt to enable storage efficiency features and automatic offline volume efficiency.
- Corrective Action
(None).
- Syslog Message
Volume efficiency features will be enabled for volume %s on aggregate %s.
- Parameters
vvol_name (STRING): Flex volume name.
aggr_name (STRING): Aggregate name.
sis.default.auto.se.enable.fail
- Severity
NOTICE
- Description
This message occurs whenever volume move is done from a non All Flash Optimized node to an All Flash Optimized node and the attempt to enable automatic offline volume efficiency failed.
- Corrective Action
(None).
- Syslog Message
Failed to enable automatic offline volume efficiency features for volume %s on aggregate %s.
- Parameters
reason (STRING): Reason for the failure.
