ONTAP EMS reference
moveagent.outofmemory events
moveagent.outofmemory EMS events occur when the move agent fails to allocate memory for the move object.
Severity
NOTICE
This message occurs when the move agent fails to allocate memory for the move object. The system continues to retry the operation until it is successful.
Corrective Action
If the problem persists, it indicates a system-level problem. Contact NetApp technical support.
Syslog Message
Unable to finish the volume move operation for DSID %llu. Failed to allocate sufficient memory.
volume_dsid (LONGINT): Source or destination volume data set ID (DSID).
