moveagent.outofmemory events
Creating your file...
Your file is ready
- Severity
NOTICE
- Description
This message occurs when the move agent fails to allocate memory for the move object. The system continues to retry the operation until it is successful.
- Corrective Action
If the problem persists, it indicates a system-level problem. Contact NetApp technical support.
- Syslog Message
Unable to finish the volume move operation for DSID %llu. Failed to allocate sufficient memory.
- Parameters
volume_dsid (LONGINT): Source or destination volume data set ID (DSID).
