      mgmt.fsecurity events
mgmt.fsecurity.failure
- Severity
ERROR
 - Description
This message occurs when applying configuration of fsecurity fails.
 - Corrective Action
Wait for a while and reapply using the "vserver security file-directory apply" command. See the "vserver security file-directory" man pages for information, or if the problem persists, contact NetApp technical support.
 - Syslog Message
Failed to apply file security policy. Error: %s.
 - Parameters
reason (STRING): Reason for the failure.
vservername (STRING): Name of the vserver.
mgmt.fsecurity.success
- Severity
INFORMATIONAL
 - Description
This message occurs when a file security policy was applied successfully after a previous failure.
 - Corrective Action
(None).
 - Syslog Message
(None).
 - Parameters
vservername (STRING): Name of the Vserver.
