mgmt.fsecurity events
Creating your file...
Your file is ready
mgmt.fsecurity.failure
- Severity
ERROR
- Description
This message occurs when applying configuration of fsecurity fails.
- Corrective Action
Wait for a while and reapply using the "vserver security file-directory apply" command. See the "vserver security file-directory" man pages for information, or if the problem persists, contact NetApp technical support.
- Syslog Message
Failed to apply file security policy. Error: %s.
- Parameters
reason (STRING): Reason for the failure.
vservername (STRING): Name of the vserver.
mgmt.fsecurity.success
- Severity
INFORMATIONAL
- Description
This message occurs when a file security policy was applied successfully after a previous failure.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
vservername (STRING): Name of the Vserver.
