ONTAP EMS reference
mgmt.fsecurity events
mgmt.fsecurity EMS events occur when ONTAP encounters issues associated with file security policy application.
mgmt.fsecurity.failure
Severity
ERROR
This message occurs when applying configuration of fsecurity fails.
Corrective Action
Wait for a while and reapply using the "vserver security file-directory apply" command. See the "vserver security file-directory" man pages for information, or if the problem persists, contact NetApp technical support.
Syslog Message
Failed to apply file security policy. Error: %s.
reason (STRING): Reason for the failure.
vservername (STRING): Name of the vserver.
mgmt.fsecurity.policy.EACCES
Severity
NOTICE
This message occurs when file-directory policy apply fails due to EACCES error. When this happens, the policy will be skipped for the volume or directory.
Corrective Action
(None).
Syslog Message
Command "file-directory policy apply" failed due to EACCES error on SVM: %s. Policy will be skipped for paths: %s.
SVM (STRING): Name of the SVM on which file-directory policy applied.
ErrorPath (STRING): Volume or directory path on which file-directory policy applied.
mgmt.fsecurity.success
Severity
INFORMATIONAL
This message occurs when a file security policy was applied successfully after a previous failure.
Corrective Action
(None).
Syslog Message
(None).
vservername (STRING): Name of the Vserver.
