ONTAP EMS reference
mgmt.fsecurity events
mgmt.fsecurity.failure
Severity
ERROR
This message occurs when applying configuration of fsecurity fails.
Corrective Action
Wait for a while and reapply using the "vserver security file-directory apply" command. See the "vserver security file-directory" man pages for information, or if the problem persists, contact NetApp technical support.
Syslog Message
Failed to apply file security policy. Error: %s.
reason (STRING): Reason for the failure.
vservername (STRING): Name of the vserver.
mgmt.fsecurity.policy.EACCES
Severity
NOTICE
This message occurs when file-directory policy apply fails due to EACCES error. When this happens, the policy will be skipped for the volume or directory.
Corrective Action
(None).
Syslog Message
Command "file-directory policy apply" failed due to EACCES error on SVM: %s. Policy will be skipped for paths: %s.
SVM (STRING): Name of the SVM on which file-directory policy applied.
ErrorPath (STRING): Volume or directory path on which file-directory policy applied.
mgmt.fsecurity.success
Severity
INFORMATIONAL
This message occurs when a file security policy was applied successfully after a previous failure.
Corrective Action
(None).
Syslog Message
(None).
vservername (STRING): Name of the Vserver.
