The requested article is not available. Either it doesn't apply to this version of the product or the relevant information is organized differently in this version of the docs. You can search, browse, or go back to the other version.
mgmt.fsecurity events
Creating your file...
Your file is ready
mgmt.fsecurity.failure
- Severity
ERROR
- Description
This message occurs when applying configuration of fsecurity fails.
- Corrective Action
Wait for a while and reapply using the "vserver security file-directory apply" command. See the "vserver security file-directory" man pages for information, or if the problem persists, contact NetApp technical support.
- Syslog Message
Failed to apply file security policy. Error: %s.
- Parameters
reason (STRING): Reason for the failure.
vservername (STRING): Name of the vserver.
mgmt.fsecurity.success
- Severity
INFORMATIONAL
- Description
This message occurs when a file security policy was applied successfully after a previous failure.
- Corrective Action
(None).
- Syslog Message
(None).
- Parameters
vservername (STRING): Name of the Vserver.
