ONTAP EMS reference
dbs.ekm events
dbs.ekm EMS events occur when ONTAP encounters issues associated with an External Key Management (EKM) key server certificate nearing expiration.
dbs.ekm.cert.alert
Severity
ALERT
This message occurs when Distributed Block Store (DBS) detects that an External Key Management (EKM) key server configuration contains a certificate that will expire in less than 7 days.
Corrective Action
Renew each listed certificate and update the associated EKM key server configuration.
Syslog Message
DBS has detected that an EKM key server certificate is nearing expiration. Cluster fault type %s, fault ID %u, status %u. %s
cfType (STRING): DBS cluster fault type of the associated object.
cfID (INT): DBS cluster fault ID number associated with the fault.
cfStatus (INT): Current status of the cluster fault. 1 = New (just reported), 2 = Existing (updated), 3 = Resolved (closed).
cfDetails (STRING): Details of the certificates that are nearing expiration.
cfExtSrc (STRING): DBS cluster fault externalSource label created by the "CreateClusterFault" API command and attached to the fault for testing purposes.
dbs.ekm.cert.error
Severity
ERROR
This message occurs when Distributed Block Store (DBS) detects that an External Key Management (EKM) key server configuration contains a certificate that will expire in less than 30 days.
Corrective Action
Syslog Message
