dbs.ekm events
Creating your file...
dbs.ekm.cert.alert
- Severity
ALERT
- Description
This message occurs when Distributed Block Store (DBS) detects that an External Key Management (EKM) key server configuration contains a certificate that will expire in less than 7 days.
- Corrective Action
Renew each listed certificate and update the associated EKM key server configuration.
- Syslog Message
DBS has detected that an EKM key server certificate is nearing expiration. Cluster fault type %s, fault ID %u, status %u. %s
- Parameters
cfType (STRING): DBS cluster fault type of the associated object.
cfID (INT): DBS cluster fault ID number associated with the fault.
cfStatus (INT): Current status of the cluster fault. 1 = New (just reported), 2 = Existing (updated), 3 = Resolved (closed).
cfDetails (STRING): Details of the certificates that are nearing expiration.
cfExtSrc (STRING): DBS cluster fault externalSource label created by the "CreateClusterFault" API command and attached to the fault for testing purposes.
dbs.ekm.cert.error
- Severity
ERROR
- Description
This message occurs when Distributed Block Store (DBS) detects that an External Key Management (EKM) key server configuration contains a certificate that will expire in less than 30 days.
- Corrective Action
- Syslog Message
- Parameters
