ucore.not events
ucore.not EMS events occur when a userspace core cannot be dumped either because coredumps are not enabled or because the process called setuid, and coredump is disabled for processes that have changed their user credentials.
ucore.not.enabled
- Severity
ERROR
- Description
This message occurs when a userspace core cannot be dumped either because coredumps are not enabled or because the process called setuid, and coredump is disabled for processes that have changed their user credentials.
- Corrective Action
Contact NetApp technical support.
- Syslog Message
'Process ID %d (%s) cannot be dumped because coredumps are not enabled.'
- Parameters
process_id (INT): Process ID of the process.
process_name (STRING): The name of the process.
