      ucore.not events
ucore.not.enabled
- Severity
ERROR
 - Description
This message occurs when a userspace core cannot be dumped either because coredumps are not enabled or because the process called setuid, and coredump is disabled for processes that have changed their user credentials.
 - Corrective Action
Contact NetApp technical support.
 - Syslog Message
'Process ID %d (%s) cannot be dumped because coredumps are not enabled.'
 - Parameters
process_id (INT): Process ID of the process.
process_name (STRING): The name of the process.
