ONTAP EMS reference
ucore.not events
ucore.not.enabled
Severity
ERROR
This message occurs when a userspace core cannot be dumped either because coredumps are not enabled or because the process called setuid, and coredump is disabled for processes that have changed their user credentials.
Corrective Action
Contact NetApp technical support.
Syslog Message
'Process ID %d (%s) cannot be dumped because coredumps are not enabled.'
process_id (INT): Process ID of the process.
process_name (STRING): The name of the process.
