ONTAP EMS reference
hypervisor.phy events
hypervisor.phy EMS events occur when ONTAP encounters issues associated with the physical network interfaces on the hypervisor not meeting ONTAP® Select requirements.
hypervisor.phy.nic.count
Severity
ALERT
This message occurs when the number of physical NICs on the hypervisor is not sufficient for ONTAP® Select support.
Corrective Action
Add NICs to the hypervisor configuration to meet the requirements for ONTAP® Select.
Syslog Message
Insufficient number of physical NICs on the hypervisor: %d. ONTAP® Select requires %d NICs.
count (INT): Count of physical NICs active on the hypervisor.
required (INT): Required number of physical NICs for ONTAP® Select to run on the hypervisor.
hypervisor.phy.nic.mtu
Severity
ALERT
This message occurs when the MTU of the physical network interface is not large enough for ONTAP® Select support.
Corrective Action
The MTU for the network interface needs to be configured to the required size in the hypervisor configuration to meet the requirements for ONTAP® Select.
Syslog Message
Physical interface %s on the hypervisor is configured with MTU: %d. ONTAP® Select requires an MTU of %d.
name (STRING): Physical network interface name.
mtu (INT): MTU of the physical network interface.
required (INT): Required MTU of the physical network interface.
hypervisor.phy.nic.speed
Severity
ALERT
This message occurs when the speed of the physical network interface is not sufficient for ONTAP® Select support.
Corrective Action
Check the cabling or negotiation for the port speed to meet the requirements for ONTAP® Select.
Syslog Message
Insufficient speed of physical network interface %s on the hypervisor: %s. ONTAP® Select requires %s.
speed (STRING): Current speed of the physical network interface in bps.
required (STRING): Required speed of the physical network interface in bps.
hypervisor.phy.nic.status
Severity
ALERT
This message occurs when a physical network interface on the hypervisor is not operational.
Corrective Action
The interface, port, or cabling needs to be investigated for faults. The interface must be up to meet the requirements for ONTAP® Select.
Syslog Message
Physical network interface %s on the hypervisor is not operational. Current status: %s.
status (STRING): Opererational status of the physical network interface.
