ONTAP EMS reference
configbr.interror events
configbr.intError
Severity
ERROR
This message occurs when an attempt to create a configuration backup file encountered an internal software error.
Corrective Action
Create the configuration backup file manually by using the (privilege: advanced) "system configuration backup create" command.
Syslog Message
Configuration backup and restore detected an internal software error. Error: '%s'.
error (STRING): Internal software error.
