configbr.interror events
Creating your file...
Your file is ready
configbr.intError
- Severity
ERROR
- Description
This message occurs when an attempt to create a configuration backup file encountered an internal software error.
- Corrective Action
Create the configuration backup file manually by using the (privilege: advanced) "system configuration backup create" command.
- Syslog Message
Configuration backup and restore detected an internal software error. Error: '%s'.
- Parameters
error (STRING): Internal software error.
