ONTAP EMS reference
raid.stripe events
raid.stripe.replay.bad.block
Severity
ERROR
This event is issued when we encounter a bad block buffer entry in NVRAM during stripe replay (indicating corrupted NVRAM). Reparity will start automatically and update parity in stripes involved in recent writes.
Corrective Action
Need to replace NVRAM if observed repeatedly during different boot-ups.
Syslog Message
Bad block buffer entry in NVRAM.
(None).
raid.stripe.replay.bad.checksum
Severity
ERROR
This event is issued when we encounter a checksum error in NVRAM during stripe replay (indicating corrupted NVRAM). Reparity will start automatically and update parity in stripes involved in recent writes.
Corrective Action
Syslog Message
Checksum error in NVRAM.
(None).
raid.stripe.replay.bad.key
Severity
ERROR
This event is issued when we cannot find a block buffer using a key during stripe replay (indicating corrupted NVRAM). Reparity will start automatically and update parity in stripes involved in recent writes.
Corrective Action
Syslog Message
Stripe %llu: cannot find NVRAM slot using key %d in %s %s.
stripe (LONGINT): The stripe number.
key (INT): The key used.
vol_type (STRING): Volume type.
vol (STRING): Aggregate name if found, otherwise NOT FOUND.
raid.stripe.replay.bad.stripe
Severity
ERROR
This event is issued when we encounter a bad stripe entry in NVRAM during stripe replay (indicating corrupted NVRAM). Reparity will start automatically and update parity in stripes involved in recent writes.
Corrective Action
Syslog Message
Bad stripe entry in NVRAM.
(None).
raid.stripe.replay.nvgen.mismatch
Severity
NOTICE
This message occcurs when RAID encounters an NVRAM generation mismatch for an aggregate during stripe replay. Reparity will start automatically and update parity in stripes involved in recent writes.
Corrective Action
(None).
Syslog Message
NVRAM generation mismatch for %s %s%s.
owner (STRING): Owner of the affected aggregate.
vol (STRING): Name of the aggregate.
raid.stripe.replay.plex.unavailable
Severity
NOTICE
This message occurs when RAID encounters an NVRAM stripe entry for an offline or failed plex during stripe replay. Reparity will start automatically when the plex comes online. At that time, reparity will update parity in stripes involved in recent writes.
Corrective Action
(None).
Syslog Message
Plex %s in %s %s%s is offline or failed.
plex (STRING): Name of the plex.
raid.stripe.replay.pzero.mismatch
Severity
ERROR
This event is issued when the checksum of the parity block (as stored in the stripe slot) does not match the actual checksum of the parity block. This indicates corrupted NVRAM contents. Reparity will start automatically and update parity in stripes involved in recent writes.
Corrective Action
Syslog Message
Parity block checksum mismatch detected in NVRAM for stripe %llu in %s %s.
raid.stripe.replay.rg.failed
Severity
NOTICE
This message occurs when RAID encounters a RAID group failure during stripe RAID replay. Data ONTAP® takes appropriate recovery actions, as described in additional logged events.
Corrective Action
(None).
Syslog Message
Replay of %s %s%s, plex %s, RAID group %s, stripe %llu failed because of RAID group failure.
rg (STRING): Name of the RAID group.
stripe (LONGINT): Stripe number.
raid.stripe.replay.rg.invalid
Severity
NOTICE
This message occurs when RAID encounters an NVRAM stripe entry for a missing RAID group during stripe replay.
Corrective Action
(None).
Syslog Message
Invalid RAID group identifier %d in %s %s%s, plex %s.
rgid (INT): Identifier of the RAID group.
raid.stripe.replay.summary
Severity
INFORMATIONAL
This event is generated when stripe replay is complete.
Corrective Action
(None).
Syslog Message
Replayed %u stripes.
nstripes (INT): The number of stripes
raid.stripe.replay.vol.cleanly.shutdown
Severity
NOTICE
This message occurs when RAID encounters an NVRAM stripe entry for a cleanly shutdown aggregate during stripe replay.
Corrective Action
(None).
Syslog Message
%s %s%s was cleanly shut down.
raid.stripe.replay.volume.missing
Severity
NOTICE
This message occurs when RAID encounters an NVRAM stripe entry for a missing aggregate during stripe replay. Reparity will start automatically when the aggregate appears again. At that time, reparity will update parity in stripes involved in recent writes.
Corrective Action
(None).
Syslog Message
Cannot find aggregate with identifier %s.
volId (STRING): Identifier of the aggregate.
raid.stripe.replay.volume.offline
Severity
NOTICE
This message occurs when RAID encounters an NVRAM stripe entry for an offline aggregate during stripe replay. Reparity will start automatically when the aggregate comes online. At that time, reparity will update parity in stripes involved in recent writes.
Corrective Action
(None).
Syslog Message
%s %s %s is not online.
