master.cast events
Creating your file...
master.cast.cm.vote.against
- Severity
NOTICE
- Description
This message occurs when the master service of the associated node cannot connect to current cluster master. It tries to cast a vote against current cluster master in the global database. The current cluster master is demoted if more than half of the cluster nodes vote against it, and a new cluster master is promoted.
- Corrective Action
(None).
- Syslog Message
Service ID %u on node ID %u (UUID: %s) has voted against current cluster master with sequence number %u and service ID %u based on "%s". The current MVIP address connection state is "%s" with duration %s. The best connection state is "%s".
- Parameters
serviceID (INT): Service ID that identifies the associated master service.
nodeID (INT): Node ID number of the associated node.
nodeUuid (STRING): Node UUID of the associated node.
sequenceNumber (INT): Sequence number of the cluster master.
lastKnownClusterMasterServiceID (INT): Service ID number of the cluster master last known by this node.
reason (STRING): Reason for casting the vote against current cluster master.
currentState (STRING): Current MVIP address connection state.
currentStateDuration (STRING): Duration of current MVIP address connection state.
highestState (STRING): Best MVIP address connection state reached since the node connected to current cluster master.
