ONTAP EMS reference
master.cast events
master.cast EMS events occur when the master service of a node cannot connect to the current cluster master and casts a vote against it in the global database.
master.cast.cm.vote.against
Severity
NOTICE
This message occurs when the master service of the associated node cannot connect to current cluster master. It tries to cast a vote against current cluster master in the global database. The current cluster master is demoted if more than half of the cluster nodes vote against it, and a new cluster master is promoted.
Corrective Action
(None).
Syslog Message
Service ID %u on node ID %u (UUID: %s) has voted against current cluster master with sequence number %u and service ID %u based on "%s". The current MVIP address connection state is "%s" with duration %s. The best connection state is "%s".
serviceID (INT): Service ID that identifies the associated master service.
nodeID (INT): Node ID number of the associated node.
nodeUuid (STRING): Node UUID of the associated node.
sequenceNumber (INT): Sequence number of the cluster master.
lastKnownClusterMasterServiceID (INT): Service ID number of the cluster master last known by this node.
reason (STRING): Reason for casting the vote against current cluster master.
currentState (STRING): Current MVIP address connection state.
currentStateDuration (STRING): Duration of current MVIP address connection state.
highestState (STRING): Best MVIP address connection state reached since the node connected to current cluster master.
